Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 10 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
Veillez à ce que les composants internes ne se renversent pas.
Retournez la console vers le haut.
Retirez le boitier supérieur du châssis en soulevant doucement la partie supérieure de la console.
[* icon_caution] Internal components can be loose. Be careful that the internal componentsthey do not topple outfall out when removing the cover.
[* black] '''FlipTurn the console topside up.'''right side up.
[* black] '''Remove the top cover''' of the chassis by gently lifting the upper portion of the console.
