Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 43 tutoriels qui comprennent cette étape.
Traduction de l’étape 22
Étape 22
Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
[* icon_caution] Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners. [* black] Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface. |
[* black] It may be necessary to slowly lift from one side, to peel against the remaining adhesive. |
[* icon_reminder] After the adhesive is cut, it cannot be used to re-seal the display in place. [guide|30512|Follow this guide|new_window=true] when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure. |
