Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 24 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Lift the left speaker straight up and remove it from the iMac. If the gap between the hard drive and logic board was too narrow to free the speaker cable earlier, gently pull it free as you remove the speaker. Push from the connector end as you pull from the speaker end to thread the cable under the hard drive's right bracket.
  • Lift the left speaker straight up and remove it from the iMac.
  • If the gap between the hard drive and logic board was too narrow to free the speaker cable earlier, gently pull it free as you remove the speaker.
  • Push from the connector end as you pull from the speaker end to thread the cable under the hard drive's right bracket.
Soulevez le haut-parleur droit en le tenant bien droit et sortez-le de l'iMac.
