Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 16 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 19
Étape 19
While holding the display up with one hand, use the other hand to unplug the display power cable. Make sure that you pull the cable out from the plastic tab, and not by pulling on the color wires. Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
  • While holding the display up with one hand, use the other hand to unplug the display power cable. Make sure that you pull the cable out from the plastic tab, and not by pulling on the color wires.
  • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
Tout en maintenant l'écran d'une main, débranchez son câble d'alimentation de l'autre main.
Soulevez l'écran suffisamment pour accéder sans difficulté aux connexions (environ 20 cm), mais pas trop, afin de ne pas soumettre les câbles et les connexions à des tensions excessives.
