Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 5
Étape 5
Remove the screw located at the top of the power switch panel. Gently lift and remove the panel from the switch side Gently lift and remove the panel from the switch side
Remove Power Switch Panel
  • Remove the screw located at the top of the power switch panel.
  • Gently lift and remove the panel from the switch side
Retirez la vis du haut du panneau de l'interrupteur d'alimentation. Retirez délicatement le panneau des chevilles en commençant par le côté du commutateur.
[title] Remove Power Switch Panel
-[* black] Remove the screw from the top of the power switch panel. Gently remove panel from pegs starting from switch side.
+[* black] Remove the screw located at the top of the power switch panel.
+[* icon_caution] Gently lift and remove the panel from the switch side
