Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Traduction de l’étape 1
Étape 1
Remove the following four connections:
Two ribbon cables -- flip up latch and remove horizontally.
One wire clamp -- use an opening tool to pry it up vertically.
One wiring harness -- use your fingers, a PSP opening tool, or tweezers to disconnect the connector horizontally.
[* black] Remove the following four connections: | |
[* blue] Two ribbon cables -- flip up latch and remove horizontally. | |
[* violet] One wire clamp -- use an opening tool to pry it up vertically. | |
- | [* green] One wiring harness -- use your fingers, a PSP opening tool, or tweezers to disconnect the connector horizontally. |
+ | [* green] One wiring harness -- use your fingers, a PSP opening tool, or [product|IF145-020|tweezers] to disconnect the connector horizontally. |
[* icon_caution] The ribbon cable near the wire clamp has a brown tab that should be lifted using an opening tool prior to removal. Be careful to not damage the ribbon or connector. |
