Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 2
Étape 2
First use a thin metal spudger to remove the four self-adhesive plastic dots covering the screw holes. Remove the four Phillips screws holding the cases together. You'll need a thin-shafted screwdriver to remove them. Ventilation holes abound in the top and rear outer cases. Such a Swiss cheese case design allows the chumby to cool off without the need for a fan.
  • First use a thin metal spudger to remove the four self-adhesive plastic dots covering the screw holes.
  • Remove the four Phillips screws holding the cases together. You'll need a thin-shafted screwdriver to remove them.
  • Ventilation holes abound in the top and rear outer cases. Such a Swiss cheese case design allows the chumby to cool off without the need for a fan.
  • There are no screws in the bottom case; it is held in place when the cases are fastened together.
  • Pull the rear case away from the chumby to reveal the spiffy internals.
Insérez ici votre traduction
