Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Traduction de l’étape 7
Étape 7
Only the screen assembly remains
Only the screen assembly remains.
If your part comes with battery adhesive pre-installed, remove its plastic liners before continuing to the previous step.
If your part has no battery adhesive, remove the clear liner on the pre-cut battery adhesive and apply the sticky section to the battery well. Remove the opaque liner before continuing to the previous step.
[title] Only the screen assembly remains | |
[* black] Only the screen assembly remains. | |
- | [* icon_reminder] Compare your new replacement assembly to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it. |
- | [* icon_caution] If you're reusing your original battery, carefully inspect it for any signs of physical damage. If it's [link|https://guide-images.cdn.ifixit.com/igi/CmJ6ZiW1sIQZLjoC.full|bent, creased|new_window=true], [link|https://guide-images.cdn.ifixit.com/igi/OrnT4eml322MUDj1.full|dented, or scratched|new_window=true], [guide|161532|replace it with a new battery|new_window=true]. ***Installing a damaged battery is a safety hazard.*** |
+ | [* icon_reminder] During reassembly, compare your new replacement assembly to the original part: |
+ | [* black] If your part comes with battery adhesive pre-installed, remove its plastic liners before continuing to the previous step. |
+ | [* black] If your part has no battery adhesive, remove the clear liner on the pre-cut battery adhesive and apply the sticky section to the battery well. Remove the opaque liner before continuing to the previous step. |
+ | [* icon_caution] If you're reusing your original battery, carefully inspect it for any signs of physical damage. If it's [link|https://guide-images.cdn.ifixit.com/igi/CmJ6ZiW1sIQZLjoC.full|bent, creased|new_window=true], [link|https://guide-images.cdn.ifixit.com/igi/OrnT4eml322MUDj1.full|dented, or scratched|new_window=true], replace it with a new battery. ***Installing a damaged battery is a safety hazard.*** |
