Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
You may find removing the system fan is unnecessary to remove the power supply cable from behind it, but if you're unfamiliar with how the power supply cable is situated behind the fan, this step is useful in seeing this. Disconnect the optical drive IDE/ATA-33 cable from the logic board.
System Fan
  • You may find removing the system fan is unnecessary to remove the power supply cable from behind it, but if you're unfamiliar with how the power supply cable is situated behind the fan, this step is useful in seeing this.
  • Disconnect the optical drive IDE/ATA-33 cable from the logic board.
  • Disconnect the system fan 2-wire power cable connector from the logic board.
Insérez ici votre traduction
