Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
The USB board is secured to the display assembly with light adhesive. Depending on your carrier the USB board may have an additional antenna cable on the back side of the USB board. Pry very carefully and stop if you encounter resistance. Gently insert the flat end of a spudger beneath the USB board to free it from the adhesive holding it in place.
  • The USB board is secured to the display assembly with light adhesive.
  • Depending on your carrier the USB board may have an additional antenna cable on the back side of the USB board. Pry very carefully and stop if you encounter resistance.
  • Gently insert the flat end of a spudger beneath the USB board to free it from the adhesive holding it in place.
  • Go slow and be careful not to bend the board.
Insérez ici votre traduction
