Aller au contenu principal
Google Pixel 8 Pro Earpiece Speaker Replacement
Anglais
Français
Traduction de l’étape 9
Étape 9
Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna board: étape 0, image 1 de 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna board: étape 0, image 2 de 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna board: étape 0, image 3 de 3
  • Light adhesive secures the L-shaped antenna board to the bottom of the earpiece speaker.
  • Use a spudger to pry the antenna board off the earpiece speaker.
  • Remove the board.
  • During reassembly:
  • Before securing the antenna board to the speaker, make sure the board is oriented so the antenna socket is along the same edge as the cable groove.
  • If your replacement speaker has adhesive pre-installed, remove the plastic liner and press the board into place to secure it with the adhesive.
  • If your replacement speaker doesn't have pre-installed adhesive, use thin double-sided tape such as Tesa Tape to secure the board to the speaker.
Insérez ici votre traduction
