Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 9
Étape 9
While pulling the inverter cable away from its socket on the inverter board, use the tip of a spudger to push the connector out of its socket. If the connector won't budge from its socket, insert a metal spudger or similar tool into the gap between the connector and its socket and twist to separate the two pieces.
  • While pulling the inverter cable away from its socket on the inverter board, use the tip of a spudger to push the connector out of its socket.
  • If the connector won't budge from its socket, insert a metal spudger or similar tool into the gap between the connector and its socket and twist to separate the two pieces.
Insérez ici votre traduction
