Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
If you want to remove the plastic cover completely I recommend opening it from the top side not to break any of the clips in the bottom. The cover is attached to the trackpad through rubber glue on the plastic grid and four clips in the bottom. It is a convenient and even a better method in order to not alter the fragile rubber feet. Take your time to slowly open the plastic cover from the top side. It is a convenient and even a better method in order to not alter the fragile rubber feet. Take your time to slowly open the plastic cover from the top side.
  • If you want to remove the plastic cover completely I recommend opening it from the top side not to break any of the clips in the bottom. The cover is attached to the trackpad through rubber glue on the plastic grid and four clips in the bottom.
  • It is a convenient and even a better method in order to not alter the fragile rubber feet. Take your time to slowly open the plastic cover from the top side.
Insérez ici votre traduction
