Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 12
Étape 12
If you see bulged capacitors, assume there is a residual charge. If the filter capacitor is replaced, IT MUST BE DISCHARGED. In addition, the black screw (Blue) is a ground. This capacitor is only found on older power supplies. Replacement is recommended, but not required.
Remove the power supply
  • If you see bulged capacitors, assume there is a residual charge.
  • If the filter capacitor is replaced, IT MUST BE DISCHARGED. In addition, the black screw (Blue) is a ground.
  • This capacitor is only found on older power supplies. Replacement is recommended, but not required.
  • With the power supply shield removed from the monitor, identify the power supply. Take note of the values, including the inverter cap if present.
  • Remove the 4 screws from the power supply. Once this is done, lift up the power supply at a slight angle to clear the chassis. Do not lift too much or the connector may be damaged!
Insérez ici votre traduction
