Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 15
Étape 15
Use of a Helping Hands is recommended to avoid soldering iron contact. If you do not have one, hold the board at an angle. While a partial replacement may work, the remaining capacitors will fail. Change them all while it is apart. Refer to this guide for soldering tips: Comment souder et dessouder des connexions. Move to a workspace with ventilation or use a fume extractor. Once in an appropriate workspace, desolder the old capacitors. Heat up each leg and remove it.
Remove the old capacitors
  • Use of a Helping Hands is recommended to avoid soldering iron contact. If you do not have one, hold the board at an angle.
  • While a partial replacement may work, the remaining capacitors will fail. Change them all while it is apart. Refer to this guide for soldering tips: Comment souder et dessouder des connexions.
  • Move to a workspace with ventilation or use a fume extractor. Once in an appropriate workspace, desolder the old capacitors. Heat up each leg and remove it.
  • After removing the capacitors, clean up the old solder with a desoldering braid. Lift it with the iron when removing it.
Insérez ici votre traduction
