Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 1
Étape 1
Use the flat end of a spudger to gently pry between the flash assembly and back cover to separate the adhesive. Remove the flash assembly from the back cover. You may also need to transfer the camera lens and the silicon pad from the rear case. These can be removed by prying carefully with a plastic opening tool.
  • Use the flat end of a spudger to gently pry between the flash assembly and back cover to separate the adhesive.
  • Remove the flash assembly from the back cover.
  • You may also need to transfer the camera lens and the silicon pad from the rear case. These can be removed by prying carefully with a plastic opening tool.
  • Depending on the adhesive on the rear case, you may need to tape the flash assembly down to secure it.
Insérez ici votre traduction
