Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 8
Étape 8
Open the device between 90 and 100 degrees, then rest it on its side. While supporting both halves of the device with one hand, unscrew the upper 5.3 mm T8 Torx screw.
  • Open the device between 90 and 100 degrees, then rest it on its side.
  • While supporting both halves of the device with one hand, unscrew the upper 5.3 mm T8 Torx screw.
  • Repeat the same process for the identical bottom screw.
  • Be sure to hold the display and upper case together with one hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
Insérez ici votre traduction
