Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 5
Étape 5
The 3.5 mm Phillips screw indicated below with a red circle may be absent in some models.
  • The 3.5 mm Phillips screw indicated below with a red circle may be absent in some models.
  • Remove the following 5 screws and 3 nuts from the heat sink:
  • One 3.5 mm Phillips from the lower left corner of the heat sink.
  • Three 6 mm Phillips from around the fan.
  • One 7.5 mm Phillips at the top right corner of the heat sink.
  • One 4 mm nut from the side of the heat sink.
  • Two 4 mm screw nuts with attached springs from either side of the heat sink.
Insérez ici votre traduction
