Aller au contenu principal
Toshiba Satellite C70D-A RAM Replacement
Anglais
Français
Traduction de l’étape 3
Étape 3
Toshiba Satellite C70D-A RAM Replacement: étape 0, image 1 de 3 Toshiba Satellite C70D-A RAM Replacement: étape 0, image 2 de 3 Toshiba Satellite C70D-A RAM Replacement: étape 0, image 3 de 3
  • Use a Phillips #1 screwdriver to loosen the single 7.0 mm screw from the hard drive/RAM panel.
  • You cannot remove the screw from the panel. Simply unscrew it until it is loosened.
  • Pull the cover towards you and up from the device to remove it.
  • If the cover does not come off easily, use an opening tool or spudger to gently pry the cover up.
  • Hearing a snapping noise while removing the hard drive/RAM cover is normal.
Insérez ici votre traduction
