Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 4
Étape 4
Test for continuity from the bad cylinder (coil pack connector the pcm) all cables have different color so it will be easy to identify. (most of them are in the right corner) In case you don't get continuity this means the cable is broken. ( use a jumper till you  get continuity) test the connector with the jumper cable connected. Assembly the intake manifold and re-test.
  • Test for continuity from the bad cylinder (coil pack connector the pcm) all cables have different color so it will be easy to identify. (most of them are in the right corner)
  • In case you don't get continuity this means the cable is broken. ( use a jumper till you get continuity) test the connector with the jumper cable connected. Assembly the intake manifold and re-test.
Insérez ici votre traduction
