Aller au contenu principal
Pentax Spotmatic Meter Switch Disassembly
Anglais
Français
Traduction de l’étape 6
Étape 6
Pentax Spotmatic Meter Switch Disassembly, Remove auto/manual switch lever: étape 0, image 1 de 3 Pentax Spotmatic Meter Switch Disassembly, Remove auto/manual switch lever: étape 0, image 2 de 3 Pentax Spotmatic Meter Switch Disassembly, Remove auto/manual switch lever: étape 0, image 3 de 3
  • Unhook one end of the coil spring.
  • Slide the stamping so the larger end of the keyhole can be lifted off the screw.
  • Remove the stamping from the post on the lens board using the same method.
  • Remove one X mm flat head screw.
  • Installation Note: Remove the old grease with isopropyl alcohol. Reapply a thin film of molybdenum disulfide grease to the sliding surfaces of the stamping and the switch lever. The action should be much cleaner.
Insérez ici votre traduction
