Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 8
Étape 8
iMac 27" EMC 2639 Repairability Score: 5 out of 10 (10 is easiest to repair) RAM is user-replaceable without opening the case, thanks to the rear access door.
  • iMac 27" EMC 2639 Repairability Score: 5 out of 10 (10 is easiest to repair)
  • RAM is user-replaceable without opening the case, thanks to the rear access door.
  • You can still replace the hard drive and CPU inside this machine, albeit with some adhesive cutting.
  • Components are modular and fairly easy to remove.
  • Budget-minded folks now can add a second hard drive to the base iMac because the Fusion Drive connector is no longer missing from the logic board.
  • The glass and LCD are fused together, and there are no more magnets holding the glass in place.
  • You'll have to masterfully peel off the old double-sided sticky tape and apply new tape in order to reseal this iMac into original condition.
Insérez ici votre traduction
