Aller au contenu principal
Xbox Series X/S Wireless Controller Joystick Replacement
Anglais
Français
Traduction de l’étape 24
Étape 24
Xbox Series X/S Wireless Controller Joystick Replacement, Clean the circuit board: étape 0, image 1 de 3 Xbox Series X/S Wireless Controller Joystick Replacement, Clean the circuit board: étape 0, image 2 de 3 Xbox Series X/S Wireless Controller Joystick Replacement, Clean the circuit board: étape 0, image 3 de 3
  • Use your soldering iron to heat up a through-hole on the circuit board.
  • Use a desoldering pump to suck up any solder residue from the through-hole.
  • To clear out through-holes, heat it from one side and use the desoldering pump to suck through the hole from the other side.
  • You can also use solder wick instead to remove the residual solder.
  • Repeat this for all through-holes and both sides of the circuit board.
Insérez ici votre traduction
