Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 14
Étape 14
Kindle Fire HD 2013 Repairability Score: 8 out of 10 (10 is easiest to repair). Simple, modular design means the few components that might fail can be easily, inexpensively replaced.
  • Kindle Fire HD 2013 Repairability Score: 8 out of 10 (10 is easiest to repair).
  • Simple, modular design means the few components that might fail can be easily, inexpensively replaced.
  • All the fasteners found inside are Torx T5 screws—one non-proprietary screwdriver is all you need.
  • The LCD is not fused to the display and can be easily removed.
  • The rear case is a little difficult to open, but it should be easy with directions.
  • A decent amount of adhesive is used on the battery, meaning some prying and gentle working is required for disassembly.
  • The glass panel is glued to the front plastic frame, so a heat gun will be required for replacing cracked glass (or you have to replace both components together).
Insérez ici votre traduction
