Aller au contenu principal
Anglais
Français
Traduction de l’étape 6
Étape 6
Insert the tip of a spudger into the opening located near the top right corner of the microphone assembly. Carefully pry the spudger upwards against the rear case to dislodge the microphone assembly from the adhesive securing it to the rear case. Lift and remove the microphone assembly from the iPad.
  • Insert the tip of a spudger into the opening located near the top right corner of the microphone assembly.
  • Carefully pry the spudger upwards against the rear case to dislodge the microphone assembly from the adhesive securing it to the rear case.
  • Lift and remove the microphone assembly from the iPad.
Insérez la pointe d'un spudger dans l'ouverture située près du coin supérieur droit de l'ensemble microphone.
Prenez soigneusement appui contre la coque arrière avec le spudger pour déloger l'ensemble microphone de l'adhésif le fixant à la coque arrière.
Soulevez et retirez l'ensemble microphone de l'iPad.
