Aller au contenu principal
Kinetec Spectra S1 Hand Controller Keypad Replacement
Anglais
Français
Traduction de l’étape 1
Étape 1
Kinetec Spectra S1 Hand Controller Keypad Replacement: étape 0, image 1 de 2 Kinetec Spectra S1 Hand Controller Keypad Replacement: étape 0, image 2 de 2
  • Step 1: Open the hand controller by removing all eight Pozi-drive screws from the rear side (not Phillips, but a Phillips screwdriver will work if you are careful).
  • A. If you are patient enough usually this can be done without disturbing the rubber around the hand controller. Otherwise, you can rip off the entire rubber cover and re-attach later using super glue or E6000 Quick Hold glue. It is recommended to keep the rubber intact.
  • B. Then unscrew the gland at the base of the hand controller to allow the cable to move freely
  • C. Once this has been done, both sections of the hand controller can be separated.
  • D. Then the old keypad can be removed by first sliding the locking mechanism on the flex cable (see Figure 2 & Figure 3) and then prying off the old keypad from the front.
  • E. Once the old keypad is removed there may be old glue left on the front. This can be carefully scrapped away using something like a plastic spudger tool or a plastic sticker remover.
Insérez ici votre traduction
