Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Open the rubber Digital AV Out compartment flap. Pry the battery with an opening tool. Carefully pull out the battery with two fingers.
  • Open the rubber Digital AV Out compartment flap.
  • Pry the battery with an opening tool.
  • Carefully pull out the battery with two fingers.
  • Remove the two screws that are now visible with a Phillips #00 screwdriver.
Ouvrez le rabat en caoutchouc du compartiment Digital AV Out.
Soulevez la batterie avec l'outil d'ouverture IFIXIT.
Retirez délicatement la batterie avec deux doigts.
Retirez les deux vis qui sont maintenant visibles.
[* black] Open the rubber Digital AV Out compartment flap.
- [* black] Pry the battery with the IFIXIT opening tool.
+ [* black] Pry the battery with an opening tool.
[* black] Carefully pull out the battery with two fingers.
- [* red] Remove the two screws that are now visible.
+ [* red] Remove the two screws that are now visible with a Phillips #00 screwdriver.
