Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Place the bottom of the tablet towards you. Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
  • Place the bottom of the tablet towards you.
  • Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
  • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
Placez le bas de la tablette vers vous.
Retirez les deux vis de 4,1 mm près du port de charge avec un tournevis Tri-Wing.
[* black] Place the bottom of the tablet towards you.
[* red] Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
[* icon_note] On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
