Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove the three screws holding down the hard drive. Use a Phillips PH0 screwdriver for the two silver, 3.4mm screws on the right, and use a PH1 for the black, 10.3mm screw on the left. It is not necessary to fully remove the 10.3mm screw, but if you do, be careful to not lose the spring. It is not necessary to fully remove the 10.3mm screw, but if you do, be careful to not lose the spring.
  • Remove the three screws holding down the hard drive. Use a Phillips PH0 screwdriver for the two silver, 3.4mm screws on the right, and use a PH1 for the black, 10.3mm screw on the left.
  • It is not necessary to fully remove the 10.3mm screw, but if you do, be careful to not lose the spring.
Insérez ici votre traduction
