Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Apply a suction cup as close as possible to the edge of the display. Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
  • Apply a suction cup as close as possible to the edge of the display.
  • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
  • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
  • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
  • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
Insérez ici votre traduction
