Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the two 3.4mm screws that hold down the right edge of the card with a Phillips PH0 screwdriver. The card is spring loaded at the receptacle. Unless you hold it down, the card will spring up once both screws are removed. Allow the card to lift up, and then slide it out of the black receptacle.
  • Remove the two 3.4mm screws that hold down the right edge of the card with a Phillips PH0 screwdriver.
  • The card is spring loaded at the receptacle. Unless you hold it down, the card will spring up once both screws are removed.
  • Allow the card to lift up, and then slide it out of the black receptacle.
  • When putting the card back in, make sure it is fully seated in the receptacle before pushing it down to re-insert the screws.
Insérez ici votre traduction
