Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 2
Étape 2
With the lens assembly pulled out of the camera, grasp one of the ribbon cables and gently pull it out of the connector. Then grab the other ribbon cable and remove it. Now the lens assembly is detached from the camera and can be removed and replaced if necessary. Now the lens assembly is detached from the camera and can be removed and replaced if necessary.
  • With the lens assembly pulled out of the camera, grasp one of the ribbon cables and gently pull it out of the connector. Then grab the other ribbon cable and remove it.
  • Now the lens assembly is detached from the camera and can be removed and replaced if necessary.
Insérez ici votre traduction
