Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 1
Étape 1
Place the camera so that the lens would be facing down. Use the phillips head screwdriver to remove the small silver screw in the top right corner. Gently peel back the black adhesive tape from the top edge. The tape is attached to the ribbon cable. Be very careful not to tear or damage the ribbon cable when removing the tape.
  • Place the camera so that the lens would be facing down. Use the phillips head screwdriver to remove the small silver screw in the top right corner.
  • Gently peel back the black adhesive tape from the top edge.
  • The tape is attached to the ribbon cable. Be very careful not to tear or damage the ribbon cable when removing the tape.
  • Use the plastic opening tool to pry the black locking tab up.
  • Gently remove the ribbon cable from the connector
Insérez ici votre traduction
