Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Use 1/8" allen wrench to loosen the screw inside the grip on the right side. The screw only needs to be turned a couple of times. Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
  • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
  • The screw only needs to be turned a couple of times.
  • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
  • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
Insérez ici votre traduction
