Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the battery by lifting the battery from the battery terminal. Be careful to note which end is positive and which is negative. The positive end should be facing away from the PCI slots. It is important to lift the battery as straight up as possible to avoid damage to battery or terminal.
  • Remove the battery by lifting the battery from the battery terminal.
  • Be careful to note which end is positive and which is negative. The positive end should be facing away from the PCI slots.
  • It is important to lift the battery as straight up as possible to avoid damage to battery or terminal.
  • The first photo shows the correct battery position. The last two photos show the battery facing the WRONG WAY! Remember, the positive end should be facing AWAY from the PCI slots, NOT towards them.
Insérez ici votre traduction
