Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 3
Étape 3
Pull the cooling/processing unit straight up to prevent damage to logic board
  • Pull the cooling/processing unit straight up to prevent damage to logic board
  • This will require some effort and should be done with caution to avoid damage.
  • The sleeves around the 6 screws may hold it in, if so just take a pair of needle nose pliers and gently squeeze the sleeves until it releases.
  • Pull the bottom, then side towards the bottom of the CPU case, first to move around the bottom coolant sleeve around the heat sinking bracket. *heat sinking bracket not in picture*
Insérez ici votre traduction
