Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove the T8 Torx screwdriver head and replace it with the 60 mm extension; then, add the T9 Torx head.
  • Remove the T8 Torx screwdriver head and replace it with the 60 mm extension; then, add the T9 Torx head.
  • Loosen, but do not remove the two screws at the bottom of the 1.2-inch wide gap in the middle of the internal structure.
  • These screws are spring-loaded and will stay in the device, even when loosened; however, it is still possible for them to be fully removed. Be careful to only partially loosen them.
Insérez ici votre traduction
