Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Due to variations between iBook G4 models, your heatsink may have either 5 or 6 screws. We've noted all possible positions for screws in the step below. If there's no screw to remove, then skip to the next screw. Be sure that you remove all necessary screws before attempting to remove the heat sink.
  • Due to variations between iBook G4 models, your heatsink may have either 5 or 6 screws. We've noted all possible positions for screws in the step below. If there's no screw to remove, then skip to the next screw. Be sure that you remove all necessary screws before attempting to remove the heat sink.
  • Remove the following 6 screws and 3 nuts from the heat sink:
  • One 2 mm Phillips extending from a finger on the left edge of the heatsink and adjacent the firewire port (not present on some models)
  • Three 3 mm Phillips from around the fan (some models may only have 2 screws).
  • One 3.5 mm Phillips on the left side of the heat sink (not present on some models).
  • One 4.5 mm Phillips at the top right corner of the heat sink.
  • One 6 mm Phillips at the lower left corner of the heat sink.
  • One 4 mm nut from the right side of the heat sink.
  • Two 4 mm screw nuts with attached springs from either side of the heat sink.
Insérez ici votre traduction
