Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove the four 7.5 mm T8 screws from behind the GPU on the logic board. These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver. These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
  • Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
  • These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
Retirez les quatre vis T9 de 7,5 mm derrière le GPU sur la carte mère.
Ces vis sont fixées à l'intérieur de grandes vis cruciformes #2 à ressort. Pour éviter que les plus grandes vis ne tournent lorsque vous desserrez les vis T9, tenez-les du bout du doigt ou avec un tournevis cruciforme #2.
[* red] Remove the four 7.5 mm T9T8 screws from behind the GPU on the logic board.
[* icon_note] These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T9T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
