Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Remove the spring plate from behind the CPU heat sink. Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board. Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
  • Remove the spring plate from behind the CPU heat sink.
  • Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
Retirez la plaque à ressort derrière le dissipateur thermique du CPU.
Soulevez et retirez la plaque de support derrière le dissipateur thermique du CPU. La plaque de support comporte deux bornes qui correspondent aux trous d'alignement dans la carte mère.
