Aller au contenu principal
Canon Speedlight 430EX II LCD Replacement
Anglais
Français
Traduction de l’étape 4
Étape 4
Canon Speedlight 430EX II LCD Replacement, Pry open Case: étape 0, image 1 de 3 Canon Speedlight 430EX II LCD Replacement, Pry open Case: étape 0, image 2 de 3 Canon Speedlight 430EX II LCD Replacement, Pry open Case: étape 0, image 3 de 3
Pry open Case
  • READ THIS!!!! This is not a "the bigger the hammer the smaller the problem" step. You mess this up and you will need to duck-tape your flash back together. Also...: make sure you don't snap a plastic tool.
  • Looking flat into the opening you should see a metal part far in.
  • With a flat driver try to get between the plastic casing and this metal part to pry it out of the locking notch.
  • Image 3 illustrates the metal tab you need to press down for the side to open.
  • One more time: Make sure you are getting between the casing and the metal tab. Inserting and twisting a small screw driver worked for me after a few tries.
Insérez ici votre traduction
