Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 13
Étape 13
Now that the lower edge of the board is free from the outer case, rotate the logic board toward yourself to expose its rear face. The following connector has a tendency to stick in its socket. If so, insert a metal spudger into the gap between the connecter and its socket. Twist the spudger to separate the two components.
  • Now that the lower edge of the board is free from the outer case, rotate the logic board toward yourself to expose its rear face.
  • The following connector has a tendency to stick in its socket. If so, insert a metal spudger into the gap between the connecter and its socket. Twist the spudger to separate the two components.
  • Carefully pull the optical drive connector away from its socket on the logic board.
  • Pull the connector perpendicular to the face of the logic board.
Insérez ici votre traduction
