Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 3
Étape 3
Remove the two 3.8mm PH1 screws with a Philips Head screw driver holding the right screen bracket in place. Again, wires may be blocking the accessibility to the screws, therefore you may need to move the wires around till you can access the screws. While removing the last screw, hold the screen steady with one hand to avoid binding the last screw or letting the screen fall.
  • Remove the two 3.8mm PH1 screws with a Philips Head screw driver holding the right screen bracket in place.
  • Again, wires may be blocking the accessibility to the screws, therefore you may need to move the wires around till you can access the screws.
  • While removing the last screw, hold the screen steady with one hand to avoid binding the last screw or letting the screen fall.
Insérez ici votre traduction
