Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Turn the keyboard bezel around so that the touchpad is closer to you. Disconnect the ribbon cable from the receptacle on the touchpad circuit board. The ribbon cable will not fall away because it is glued to the bracket that holds the touchpad in place Remove the four 2.9mm screws from the bracket using a phillips PH0 screwdriver.
  • Turn the keyboard bezel around so that the touchpad is closer to you.
  • Disconnect the ribbon cable from the receptacle on the touchpad circuit board. The ribbon cable will not fall away because it is glued to the bracket that holds the touchpad in place
  • Remove the four 2.9mm screws from the bracket using a phillips PH0 screwdriver.
  • To remove the touchpad, simply push the touchpad from the top of the keyboard bezel (the touch-sensitive side, not circuit board side). This should require almost no force.
Insérez ici votre traduction
