Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit. Note: You may use your hands for additional force to separate the two pieces of the outer shell. Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
  • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
Insérez ici votre traduction
