Aller au contenu principal
Anglais
Français
Traduction de l’étape 6
Étape 6
Using a flat blade screw driver, gently pry on one of the two clips that hold the retaining rings over the diaphragms. Be gentle, as this is the weakest component of the entire assembly and there are no easily sourced replacements available for these.
  • Using a flat blade screw driver, gently pry on one of the two clips that hold the retaining rings over the diaphragms.
  • Be gentle, as this is the weakest component of the entire assembly and there are no easily sourced replacements available for these.
  • Remove the ring and set it aside after a gentle cleaning of the inside of the ring.
Insérez ici votre traduction
