Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 9
Étape 9
This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals. Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone. Gently pull the ribbon from the circuit.
  • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
  • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
  • Gently pull the ribbon from the circuit.
  • Remove the now disconnected screen.
Cette étape n'est PAS requise pour la maintenance du joystick ou la maintenance et le remplacement du clavier! Continuez à l'étape 10 si vous tentez d'atteindre l'un ou l'autre de ces objectifs.
Lentement soulever l'écran pour révéler le ruban de circuit vert reliant l'écran au téléphone.
Tirez doucement le ruban du circuit /
Retirez l'écran maintenant déconnecté.
[* icon_caution] This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
[* black] Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
[* black] Gently pull the ribbon from the circuit/circuit.
[* black] Remove the now disconnected screen.
