Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 32 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case. The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage the home button cable.
Finishing the iSclack Opening Procedure
  • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
  • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage the home button cable.
  • Peel the two suction cups off your iPhone.
  • Skip the next three steps and continue on Step 9.
Tenez bien votre iPhone et serrez les poignées de l'iSclack pour séparer les ventouses et enlever la vitre du boîtier arrière.
L'iSclack est conçu pour ouvrir suffisamment votre iPhone en toute sécurité, sans risquer d'endommager les nappes de l'écran.
Décollez les deux ventouses de votre iPhone.
Ignorez les trois étapes suivantes et continuez à l'étape 9.
[title] Finishing the iSclack Opening Procedure
[* black] Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
[* black] The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage the home button cable.
[* icon_note] Peel the two suction cups off your iPhone.
[* black] '''Skip the next three steps and continue on Step 9.'''
