Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 4
Étape 4
Using a flat-blade screwdriver or other appropriate tool, pry the cover off the back of the gear housing and set it aside. There is a plastic gasket between the housing and the cover, so you'll want to watch for that and set it aside with the cover.
  • Using a flat-blade screwdriver or other appropriate tool, pry the cover off the back of the gear housing and set it aside.
  • There is a plastic gasket between the housing and the cover, so you'll want to watch for that and set it aside with the cover.
  • With the cover removed you'll see:
  • The worm gear that the electric motor turns and,
  • The main gear the turns the outer gear which then moves the regulator
Insérez ici votre traduction
