Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Lift the fan shroud and fan straight up and out. Take care to disconnect the indicated connector Remove the heatsink clamps with a flathead screwdriver and do the same for the other side. Lift off the heatsink and remove the 4 screws of the CPU board.
  • Lift the fan shroud and fan straight up and out. Take care to disconnect the indicated connector
  • Remove the heatsink clamps with a flathead screwdriver and do the same for the other side.
  • Lift off the heatsink and remove the 4 screws of the CPU board.
  • There are 4 pins: remove the 3 pins near the RAM but not the pin nearest You.
  • You are now ready to slide gently (and without ANY difficult) the motherboard. Lift up and the game is done.
Insérez ici votre traduction
